Bosch is best-in-class again, with the Bosch DH712VC SDS-max Demolition Hammer hitting the jobsite with 14.5 amps and 9.6 ft-lbs. of impact energy. Weighing in at just 18.4 lb, this hammer is 20% lighter than its predecessor to reduce stress on the body during all-day applications. A longer air cushion in the hammer mechanism, a de-coupled main handle and an anti-vibration side handle further reduces stress on the user during extended use. The SDS-max platform allows for tool-free bit changes, automatic bit locking and a maximum impact energy transfer rate. Obtain greater control during drilling and chiseling applications using the variable speed dial and an auto lock-on switch. Optimize working angles using the vario-lock function, which rotates and locks the chisel into 12 different positions. FeaturesBest power to weight ratio at 14.5 amps and 9.6 ft-lbs. of impact energy (E.P.T.A.) , providing maximum productivity in all day chiseling and demolition applicationsActive vibration control reduction in the hammer mechanism and the grip area provide maximum user comfort for extended periods of workConstant response circuitry maintains speed under load and overload protectionArticulating auxiliary handle provides maximum comfort and control by maintaining the best working posture possibleVario-lock positioning rotates and locks chisel into 12 different positionsIncludes14.5 Amp SDS-max Variable Speed Demolition Hammer - DH712VCAuxiliary Side HandleCarrying CaseSpecificationsAmperage: 14.5BPM: 2760Battery Voltage: Bit Size: Chuck Type: SDS-MaxCord Length: 8 ft. Horsepower: Impact Energy: 9.6 ft-lbs. Power Type: ElectricVoltage: 120V
Tyler Tool | [show price] |
Walmart US | [show price] |
